maxxtraxxk5
Registered Member
Hey guys, I've got an issue with my 86 K5 jimmy. here is how the truck sits now: it was a 305, and now its got a replaced 350 block and heads, with an RV cam in it( crate motor from Marshall distributers in Maine) and the stock 305 intake with a Edelbrock 1406 performer carb on it. and headers, its got the 305 distributer still in it, and about 14k on that setup. the issue I'm having is when its hot, it misfires and only runs on 6 cylinders, and if i burp it, it comes out of it, will sit and idle all day long, take it down the road fine, but then all of the sudden it will go back to running real rough, and gets to the point where it shuts off. once its cooled off, it fires right up on choke ( temp here in NH is in the high 40's today) and it runs fine, this problem seems only like its when its hot
so i have new plugs and wires to put in it, (AC Delco replacements.) i haven't had the plugs out, and i haven't found any vacuum leaks (yet). coil was just replaced to get it running, i got the exhaust patched back together, and its better than it was with the bad coil in it, cap and rotor are in good condition.
so what direction do i go with this? find someone to adjust the carb and see if its just way out of adjustment? compression test? just put the plugs and wires on it? timing issue? any help would be awesome, thanx guys!
