mtnman210
I'm trying to finish up the wiring on the project and I'm back to the alternator problem again
The first time I couldn't get it to charge. Ended up looking through a couple diagrams and came up with this
Bat terminal on back of ALT: direct to + on battery
#1: ignition switch
#2: either jumped to bat post on ALT or run all the way to + post on Battery
Now this isn't a normal column and dash setup up it's in the trail rig. I'm running a simple switch panel and have a designated IGN switch. So I've run the #1 wire to the switch and the rest of the wires as stated. I've tried #2 both ways and still have issues.
So with the wires run according to the above. I finally get a charge with the truck running but I shut off the IGN switch and even the main battery cut off switch and the truck will stay running. Any ideas???
The first time I couldn't get it to charge. Ended up looking through a couple diagrams and came up with thisBat terminal on back of ALT: direct to + on battery
#1: ignition switch
