Trugy ideas & pics
slyguy_22
Lancaster, PA
Looking for ideas and info. Lift no lift motors radiator location. post em up. pics are best!
4" lift on (still :rolleyes:) little tires. The suspension will be coming down ~2" (the lowest I can have it and still use crossover steering.
The radiator is pretty much in the stock location. Its tilted back and I had to make new lower radiator mounts (since the core support is gone). I used the stock upper radiator mount.
looks good! How did you do the cab area/floor? did you remove the firewall and just remount the steering and gauges? I was thinking of leaving the "cab" remove the front clip and doors and cut the rear fenders off and then cage from there. figured that way if i wana run it in the snow i have a lil protection from the elements. guess i could always slap the doors backon too. i was thinkin of going with no lift and 36 swampers mild 350 i have layin around and the np205 twin stick. not sure which tranny i wana use i have a Th400, Th350, and a sm465. im gona try and do mine as cheap as possible. nothing too fancy. im thinkin of makin the cage out of square tube. would that be cheaper? i know it wouldnt look as cool but im thinkin it would cut down on my expenses a lil bit.
The floor and firewall are stock, just cut to size.
Square tubing is generally cheaper than mechanical tubing (HREW or DOM) but is a poor choice for any kind of cage, IMO.
Check here if you want to see the debate between pipe, HREW and DOM.
http://coloradok5.com/forums/showthread.php?p=2017740#post2017740
fiberglass all the way baby. no more sheet metal (as soon as i can afford the front fiberglass kit from trailerproducts.:D All removable fiberglass is planned for the rocks. Reinstall the glass for street and lightduty wheeling.
4 link front and rear with 2.5 king coilovers (built by randyellisdesign.com )
tons of cage and tubing
np208
350 crate with tbi and affordable fuel injection harness
700r4
artcarr shifter
autometer gauges
renegade and beard seats
michelin military tires
steel rims
ammo cans
nato fuel cans
coming soon: front fiberglass, winch bypass shocks and revalve for the coilovers:D
