I always wonder about your 12 bolt,at the speeds you go and the jumps... do you ever worry about a failed c clip and loosing an axle.
Or do you got a fix for that??
yup it is called a 14 bolt
Disc brakes are better than nothing. At least the wheel won't come off. Another fix would be to just not worry...I always wonder about your 12 bolt,at the speeds you go and the jumps... do you ever worry about a failed c clip and loosing an axle.
Plus the pumpkin had to be repaired a wee bit tooI did not do it myself. I had to use our local diff shop, not all of us have the luxury of a bitchen fab shop at our finger tipsPlus the pumpkin had to be repaired a wee bit too
. I told him I did with that pinche little Hickey truss then we both laughed. Actually I think it all started way back in the beginning on some of the test runs before I re-installed that little truss and it just got progressively worse. I've been watching it bend for at least a year or so now
My 10bolt is trussed from shock mount to shock mount. Still bent it in the dunes in Michigan. The last 2 inches on both sides. Next truss will go to the inner C.
Adam to answer your question the pumpkin needs to be pre-heated and welded with nickel rod. Then wrapped with some welding blankets to cool slowly.
