Tuff Country traction bars
Look into something like Kerts Wraptor.
A single bar will help a little when installed right but it will not eliminate all wheel hop and will limit articulation.
Something like DIY4xs wraptor will.
Its a double system. I do see what your saying about articulaton.
That doesn't help near as much because it puts the spring under compression and it can still bend and wrap. It is much more effective when it puts the spring under tension, like a caltrac. But those will limit the articulation. DIY4X and ORD traction bars are a much better design for our rigs. For straight drags the caltrac is where it's at because it allows for an adjustable IC.
I am talking about an upper and lower bar. There system using a bar on each side it looks like. But they both go to the same place.
Any fixed bar on a leaf spring setup will limit articulation, some will limit it drastically.
Thanks for the help guys, im gonna look into other options.
