myraley
Hi guys. I have two in-line smaller than normal glass fuses by the firewall, and I cant figure out what they go to. They are powered off the Alternator and starter solenoid junction, so they are always hot. The wires are black with a white stripe and black with (I think) a brown stripe. And there are these two little fuses in these rubber holders in the wiring itself. They go into the firewall panel on the top drivers side, next to the red wire that is also coming from the alternator / starter junction. I looked at a wiring diagram, and they just seem to go into the cab and then end... Any ideas? Do I need these or can I get rid of them? I am trying to clean up my engine wiring. Thanks!
Eric
Eric
I still have it bookmarked. I went with 2 and 1/16 gauges instead (I figured that way if I screwed up the hole, I could just enlarge it and go 2 and 5/8, but other than that, its the same and it turned out awesome! Thanks of all the images on that.
The only one that isnt working right now is the trans temp, and thats because I need to go get the sender bung brazed into the pan. I have a TH400 and I tried putting it in the pressure port on the drivers side, but I got all kinds of fluctuations, so I'm gonna go with the pan. In your images under Misc. Stuff, you have one called "electrical problems circled" and you have one of these two fuses I am talking about circled in red. Why? what happened?
