U bolts 14 bolt
85blazer350
Grande Prairie,Alberta,Canada
Ive got the 14bolt rear end all rebuilt and am putting it in tomorrow I need to know which u-bolts to buy and how do i rig up the e brake cables.becuase they are brand new but each 1 only reaches to the middle of the diff.
Thanks
I cant help with the E-brake(I dont have one), but the U-bolts should be size 5/8" x 3 1/2" x 8". That is assuming youre not using rear blocks. If you are, add the block height to the length of the U-bolts.
The actual inside diameter of the 14FF tubes are 3 3/8". /forums/images/icons/wink.gif
