U joint confusion
TJ1978
I have MANY questions
East Valley, Arizona
For 69 c10
I have confused myself on this
GM 12 bolt rear what U joint size? They said it’s 1310 from differential pic but I’m not sure. Doesn’t look like 1330 and certainly not 1350
When you're measuring the yoke, get the distance between the retaining tabs - not the overall width.
Iirc, a 1330 should be longer on one side where 1310 & 1350 are the same width on both sides of the cross.
What is the distance from inside of tab to the opposite inside of tab on the yoke? Measure outside to outside on u joint. What is the diameter of the u joint cup?
The 1330 and 1350 both measure approximately 3 5/8 wide. The 1310 and 1330 series can have cap diameters of 1 1/16 and/or 1 1/8 inch or a combination of both sizes. The 1350 series has a cap diameter of 1 3/16 inch and the body and journals are bigger than the 1310 or 1330.
The digital read is screwy so..
looks/measures 1310 to me...
looks to be 1310 or the corporate joint, 3r or something on that order. Dennys driveline
Driveshaft and Driveline Parts > Universal Joints > U-Joints BY SIZE > 3R Series U-Joint 2.556 X 2.556 - 1.125 inside c clips > 1.125 X 1.125 Bearing Cap ...
this is a combination joint
1310 to 3R series Combination Universal Joints · 2.556 inches wide between the yoke inner surfaces where the "C" Clips lock in. · 2 bearing caps are 1.125 inch (1 ..
I was on so many different websites including the one you quoted from. Just made everything even more confusing.
what prompted the frantic posting/searching is, I ordered my driveshaft today and after measuring, talking with them and sending pictures, I got worried I may have ordered incorrectly.. Driveshafts aren’t cheap so... hahahaha
Thankfully, they are local in the event any issues arise.
@frankin5
