kphx87blazer
Registered Member
Hello,
Long time lurker, first time poster. I searched through some other recent posts.
Anyways...
I was driving a 1993 5.7 IFS Blazer but picked up a solid axle 87 blazer off craigslist. The thing looks great, very clean. The previous owner said a lot of engine upgrades were done ie "cams" and stuff. I dont really know about all this stuff yet but im learning. Its got aftermarket exhaust and its very clean. i figure its got about 160,000+ on it. The truck apparently "sat for 6 months" prior to the sale.
Anyways, The thing has good oil pressure, runs great at highway speeds. But while sitting at a stoplight or pulling into the garage, with the foot on the brake it stumbles, runs really rough and almost stalls. It did stall once but started right back up. Putting it in neutral or park increases the idle and solves the problem somewhat but still runs a bit rough but not near as bad. The truck came with a half tank of gas and I filled the tank right after purchase. So the gas is still in there.
My plan is this:
**Change the spark plugs, wireset, distributor, cap and rotor. Change the fuel filter also.
The air filter came with the top that was quite a bit smaller than the rest of the assembly, so i went to the junkyard and bought the top to fit the entire assembly. Put in a new air filter.
So am i on the right track?
My buddy says the idle may be turned down to low. But you cant just adjust it on this engine. Dont you need a snapon tuner or something?
I thought about vaccuum lines. But Im sorry to admit, I dont have a fekin clue as to where the vaccuum lines are. Does anyone know where I can get some pictures of where the vaccuum lines are?
What about the 02 sensor? Where is it located?
Am I on the right track? Any other ideas?
YOUR COMMENTS ARE APPRECIATED!!!!!
I just want a nice s-m-o-o-t-h idle or am I asking to much from a vehicle thats 20+years old?
Anyways...
My plan is this:
