Update on 12 1/4" travel Gabriels in stock mounts
Discussion in 'The Garage' started by Emmettology 101, Sep 19, 2002.
  1. Emmettology 101
    Emmettology 101 3/4 ton status Premium Member
    May 9, 2000
    8,131
    FL
    Update on 12 1/4\" travel Gabriels in stock mounts
    Well I flexed it up a week or so ago and walked around it and looked at the mounts. THe rear was fine since the gabs were almost identical length to the Es3000's that were already on it.
    The fronts need to have the mounts moved a little. When the suspension compressed, the shock totally compressed and limited up travel and flex. I will be making new mounts and extending them up a few inches to increase flex and up travel. However, I dont want to extend them too far up because that would limit downward travel. I feel about 2 inches should do it, but I will be removing the shock and measuring the collapsed length first so I get a correct extended tower length.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: Update on 12 1/4\" travel Gabriels in stock mounts
    This is on the stock mounts? with how much lift?
  3. Emmettology 101
    May 9, 2000
    8,131
    FL
    Stock mounts with 6" Superlift Superrides.... I was just going to leave it go, but the front limited upward travel is pulling a rear tire too soon. So if I extend the shock mount up a little, I should gain a little more rear downward travel!
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    What kind of shock mount were you thinking of using? I've got the same lift and am interested in your results.
  5. Emmettology 101
    May 9, 2000
    8,131
    FL
    I was going to use a 2.250"X 2.250" x 3/16"wall square tubing and make my own mounts(or soemthing similar).... I dotn want to extend them too much and loose downtravel... The Blazer still worked great set-up like it is, but I noticed the rear pulled off the ground a little too soon.
    The rears are stock springs with a thick add-a-leaf(yuk) and a 4" block... I have F150 springs I will be swapping in one day...
