Problem: My nearly 45 year old 2-core radiator developed a pinhole about halfway up on a seam. I last had this radiator 'rodded' back in 1993. This radiator has no aluminum - it is the old style brass.
Background: During the past 23 years I have had this blazer the cooling has been marginal at best. This is a 2-core and I think it is 17" high. On hot days on a long incline I sometimes have to turn on the heater to keep from overheating. At idle it seems to hold the temperature ok. During normal driving on a warm day the temperature fluctuates between 180 and 200 deg F. In offroad conditions, high power, low forward speed, hot day, it is less than marginal.
Solutions:
Here are a few relevant threads
Solutions:
- Have someone 'rod out' and reseam the 2-core radiator and keep my marginal cooling.
- Back in highschool guys were putting 4-core radiators in with the higher top mounting bracket. I heard that the 4-core did not help; the first two rows do all the cooling anyways.
- I have seen custom aluminum radiators advertised that improve cooling. https://en.wikipedia.org/wiki/List_of_thermal_conductivities All hugely dependent on specific alloy and I have seen some report this as reversed, depends on copper components.
- Brass thermal coefficient 125 + copper thermal coefficient 400
- Aluminum thermal coefficient 235
- 4 core https://ck5.com/forums/threads/4-core-radiators.300719/
- Good list of sources for brackets and stuff http://www.chevytalk.org/fusionbb/showtopic.php?tid/13083/
- Just to check on the 'do brass radiators wear out' I looked at Model A radiator site, the originals are sill going strong with rebuilds http://modelaclub.com/archives/tech-tips/532
- Source of direct fit
- Copper/brass
- ecklers trucks 4 core replacement http://www.ecklerstrucks.com/chevy-...or-v8-with-manual-transmission-1973-1977.html
- aluminum radiators
- Copper/brass
- Neutral on copper versus aluminum
- good back and forth thread http://www.v8buick.com/showthread.php?263299-4-core-Brass-Copper-radiator-or-Aluminum-radiator
- pragmatic view http://www.caparadiator.com/aluminumvscopper.html
- explains it is design not material http://www.hotrodhotline.com/md/html/aluminum_vs_copper.php
- if in doubt aluminum it out http://www.cgj.com/2013/07/16/aluminum-vs-copper-brass-radiator-final-thoughts/
- Has anyone measured the real difference between the brass 2-core and 4-core?
- Has anyone measured the real difference between the brass and aluminum?
I like numbers, it's all learning.
