- Joined
- Mar 3, 2000
- Posts
- 9,123
- Reaction score
- 7,077
I want to install some bump stops before blazer bash. Probably just the rubber or poly type. I got some rubber ones from Norby that will work on the front.
My question is how much up travel on the axles front and rear would you say is enough?
70 jimmy with 37" Krawlers, 14 bolt rear with Detroit, 10 bolt front, nothing fancy for shocks, rear are in boarded. All leaf spring suspension, 6 " in front, realistically 7" or so in rear with combo of super shackles, shackle flip. Springs are Tuff country easy rides. Crossover steering with hydro assist if that matters any.
Thanks.
Thanks.
