using truck cabs on k5 frames? can you?
mwood1985
Marietta Ga
so i crushed the roof in on my k5 and ive been toying with the idea of a truggy. i keep seeing truck cabs from the early 60s on up to 87 on a k5 frame. are the body mounts the same as a blazer as they are on a pickup cab or are they making new mounts? from what i can tell it dont look like they are doing much to put the cab on the k5 frames
Search for "Trazer" here - there have been many builds.
pull blazer tub
bolt cab on front 2 mounts .
level cab .
make cross beam for back 2 mounts .
flatbed it or cut down box and custom mounts to hold it and your done.
like said TRAZER builds around here on the site with pics.
pull blazer tub
level cab .
^This^ With your 86 frame, you will have to make something for the rear of the cab to mount to. The front mounting is the same as your blazer tub
