very little pinion play
88k5blazin
clark new jersey
I got everything back together on the third member for replacing the crush sleeve. Before I go any further I wanna check in. It has a bearing pre load of 7 in lbs at the moment and there is a very very small bit of wiggle on the pinion. Is that normal play between the bearings or should it be completely snug. I know the rating calls for between 5 and 15 in lbs but it feels pretty snug when I spin freehand. Is that normal or should it be able to spin a little on its own. Thanks for any advice
"Preload " to me implies that the bearings have been brought to zero play....and then "preloaded" with an additional amount of force....
I would assume zero play or wiggle would be what you are looking for.....
When I would pack old style wheel bearings, I would tighten the spindle nut until there was a significant amount of drag on the hub...insuring that all slack had been removed...the spindle nut was then loosened,,until a preload was still on the bearings.....and then locked in place....
the pinion bearings are no different....
what axle for the record ?
this might help get you a tip or trick better on checking that.
and new or used bearings ?
Are you reading the amount of force it takes to keep turning the pinion or the amount of force it takes to START turning the pinion?
You want the first.
I got the little bit of wiggle out and now I have a rotating force of 5.5 in lbs. Do u guys think that will suffice?
