WANTED-Dana 60 brake calipers
and if i recall correctly all 1ton 2wd front calipers are the same as dana 60 . find a 2wd and grab them for core or junk yard might have a like new set out there.
2WD calipers from a 1 ton are not the same, D60 calipers are a one of a kind.
o.k. cool info. thay looked close but never got to checking them out.
do you happen to know the specifics on why not?
96 p30 ifs front i work on a lot at work with 10,000 gvw looks the same as my dana 60 .
are you talking the bigger solid beam axle or newer truck k30 stuff with 2 slide pins.
just checked autozone online.
88 v30 4x4 frt is same as 96 p30 ifs front . but i do know that 88-up is totaly diffrent.
as for the cores, you dont even have to have D60 calipers for cores, the idiots that work at crapa or autobone wont know the difference, when you go in look for the stupidest guy, that will save ya the core charge
Wow, i wasn't even thinking about anything that new, i was thinking the same old body style stuff.
Yea, I just bought some and they were $33 + $25 core.
dude, where did you buy them from? the vatozone down here wants double that.
does anyone know a good source for the slide pins, because i don't have those either.
almost all the reman calipers come with the plate/spring/bolt for the hold down . check the box first. if not ask for a hold down or hardware kit.
