Water Temp sender
In my underwear
Administrator
Author
CO
OK, I wanted to put my manual temp sensor in the passenger side head, long story short I had a problem with the plug not coming out so now it is welded shut and no longer an option and it is the only plug on that side. I also only have one plug on the other side that has a temp sender in it for the TBI I think?
Is there some kind of t-off that I can put in that side that will work with that sensor and my manual temp gauge or should I slap it in the intake manifold somewhere?
you could go to a hardware store and get some npt fittings... because of the length of the senders it would have to be a nipple, a tee, nipples of that and then unions... would be much easier to stick it in the manifold.
driverside should be an electric unit for the dash gauge.. should be able to just pull that and put it in. tps is in the intake.
you can also get a waterneck with a 1/2 npt port in it if need be...
something like this...
That's what I wasn't sure about, I knew one of the temp sensors was for TBI didn't know which was which, I don't need the electric unit for the dash as I no longer have factory gauges so sounds like I can get rid of the factory gauge sensor there and install my aftermarket sensor.
Yep, the one in the drivers side head is the one for the factory electrical gauge, it has some type of 'slide' connector on the wire, like a spade that slides over the end of the sensor. The one in the manifold, for the tbi, should have a plug in style connector, 2 wires IIRC.
Sweet, that makes my life a whole lot easier. :D
