KansasTwister
So I found the noise in the k5, rear u joint on the axle side is toast. So planning on changing it at the transfer case and the axle side. Should be a gm s44/3rl on both right? Is spicer the best to go?
Stock 86 k5 with 700r4/208/10 bolt.
