CK5 Network
Become a member of the largest online community for Chevy K5 Blazer, Suburban and C/K series truck owners!
what brand tube bender to get?
KeyBlazer
Premium Member
Irvine, California
Over the weeks that followed it was blasted, and powdercoated.
My garage is a post tension slab, so cant drill, so needed another solution.
Swag Offroad/HF 8t Long Ram conversion...
Powdercoated
KeyBlazer
Premium Member
Irvine, California
Then I added the Swag Offroad revolver base...
And build a rolling table with multiple trailer hitch receivers so I can mount it on top or on sides, and other stuff..
F3E54F86-4F90-478E-B488-36E42879139C.jpg 3958EAD0-D99D-4A80-BB58-84ADD02CD102.jpg
Works good tho so far I only did test bends
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
I have a JD squared model 32 bender. I like it because of the capacity and strength, and the cost difference was minimal. It can bend 2" x 1/4 wall if needed.
I use an air/hydraulic pump because its a lot cheaper than the electric hydraulic pump. I did put a pressure gauge on it so I don't go over the limit of the bender.
I built a stand for it out of 2.5" x 1/8" wall square tubing, and just wheel it where it needs to be to clear the walls for the bend then roll it back in the corner, which is easier with the hydraulic since you don't have to crank on it and have it stay still.
BoondocK5
Chevrolet Bone Collector
Premium Member
Author
Salt Lake City, Utah
I saw this one, and knew it was the one I wanted.
I haven't used it yet, been a bit busy with other stuff.
Tnsejed
6al4v
Premium Member
Florissant, CO
I've had good luck with my JD2 dies. They are older though, can't say if new is any different.
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
1.625 (chrome moly), 1.75 (regular DOM), 1.5, 1.25 the most. I also have 1 and .75.
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
Are those aluminum dies? That would be handy, my 1.75" dies are damn heavy.
How tall is your ceiling, have you had any issues with tubes hitting it during bending?
One of the reasons I like it on wheels is because while bending main hoops and such you can roll it so the tube clears while bending.
BoondocK5
Premium Member
Author
I've only bent a couple pieces of 1.75" x 0.125 wall. The ceiling in my garage is about 8'.6",
I would have to be careful if bending any kind of length over about 6'
Not a problem, yet. Those dies are aluminum, while lighter than steel, they're still pretty hefty, more than you'd think.
