My 383 with tune runs really great with a minor issue.
Every once in a while not always it will stumble when you get on the throttle from idle. I have a 54mm TBI.
What I have read and seen is its not enough air getting past the butterfly valve at idle. You can crack that valve open some to get more air by but then run into problems with idle surge because the idle valve isn't able to keep up.
This doesn't occur all the time the majority of the time things work perfectly. But it does suck sitting at a light and then stepping on it and have the engine die especially when pulling a load. Smash the throttle more and it wakes right up. Any other things I might try?
