What do you need to do for BB12?
Bent77
I am CK5
Nunya
Permission from boss
PS box repair
overall vehicle check for need-fixins...
Add a few tubes to the cage (Eric recommended a few improvements last year)
T-case brace
shorten front driveshaft
mount fire extinguishers
add trans cooler
CB radio
Fix fuel filler (leaks)
change cable on winch
rock lights
replace rear freeze plug
replace u-bolts
add bumpstops
build trailer (or find one to borrow)
finish on board air
and if I have time I may do a cam swap
ride my m/c about 3500 mi to get there, then hitch a ride!
Repair the a/c. Add the XM. Going in style this year. As much style as a thrashed truck can have.
I just registered, now have to do a few small upgrades. See everyone there!
All of the big work is done :laugh::
D60 w/Lock Right, 35 spline outer shafts, Warn Premium 35 spline hubs
PSC Hydro Assist
ORD 203/205 doubler w/triple stick
Line-lock e-brake
14 bolt w/ARB and disc brakes
4.56 diff. gears
17x10 Marsh Racing wheels w/3.5" BS
37" Bias Bit Bull Rockers
The rest is minor repairs, clean up, and cosmetic stuff.
Dustin - let's go back to Green Day!
Yes it is! Everything came together over the last year to do the upgrades. I had bought the axles prior to BB last year. Then got a great deal on a ready built 203/205 doubler.
Dam Jack, looks like you've been pretty busy with your K5...nice!
It has indeed, and where are the pictures? Holding out on the truck porn...unacceptable
I have to find $1000+ in gas money and 5+ days off work. Shouldn't be too hard :D
