So i noticed a while back my filer neck was leaking during fill up. Upon further inspection, the fill-pipe is loose from the tank, you can slide it up and down rather easily. Its a 90' so it came with TB, but PO converted to carb. What tank should i go back with? I am thinking the TB tank had more lines coming out that i wouldn't need (or it may just be for that style fuel pump assembly?)
It does have a manual fuel pump on the engine.
