What gear is this? Picture...
K5_Fla
FLORIDA
what gears do I have? .. this is the front diff. I thought I had 3.73... looks like 4.11 ?
That means 41 teeth on the ring gear and 11 teeth on the pinion gear so divide the ring gear by the pinion gear and you have 3.73's
And for the 3rd time, yep, 3.73 ratio.
If you want 4:10s, you just grind one tooth off the pinion gear, giving 41:10 --> 4.10:1.
Hmmm...maybe I should put some disclaimers in here...
