oldtoyboyd
I have a couple trucks that I have bought over the years and looked at that give standard equipment gears instead of the ratio. Is there a chart or listing on what standard gears for what years and what models?
That was what I was guessing also. I can't read any online brochures that I have found. The print is too small to make out.I'll venture a few uncertain guesses...
1/2 ton - up to mid 80's = 3.08, late 80's+ = 3.42
light duty 3/4 ton = 3.42
hd 3/4 ton = 3.73
1 ton = 3.73
These are just guesses based on junk I've seen over the years but I feel fairly confident about them. Also, I've seen more 4.10 1 tons than 3.73 but you are asking about base model ratios. Of course "standard" could vary from year to year, it would take some time but searching Dremu's brochure collection would tell you for sure.
RPO codes list standard gears instead of number but will give gear number for optional gears. The burb I just bought has standard gears according to rpo code.I don't think there is any "standard" about gears. I have seen the same year and model all with different gearing options from the factory.
Check out this site, there is a menu on the left of the page where you can look up RPO codes.
http://www.c2e.info/rpocodes/
I love this kinda info...
That being said, my 79 k5 came with 3.73 factory... 350, t350, tc unknown(PO swapped in t400/205), 10b/12b...
My 88 V30 came with 4.56 from the factory... 454, t400, np205, 60/14 srw with gov bomb...
