What size banjo bolt??
85mudblazin
Austin,TX
I am going to be buying the az-kickin disk brake hose kit for my 14bff and I dont know which size banjo bolt I need there is either 10mm or 7/16.
Thanks
-Chris
Probably a 10mm. Depends on what year caliper you end up with. When you pick up your calipers ususally the auto parts store that you get them from will have those as well. Just test fit the banjo bolt right there. Check them both too. I have already had a mismatched pair.
I am going to be buying the caddy calipers with the e-brake that make a difference in which size banjo??
Thanks
-Chris
Great thanks, muddytazz hasnt pm'd me back yet, good now I can go buy all my goodies!!!!!
Thanks
-Chris
