scottsdale86
the 2770 KD tool is too big. Already tried it. What i need measures about 2 inches across.
yeah well then you would be buying a new spindle because you ruined the threads. That isn't the way I want this to go. You are APPLYING standard knowledge to an NONSTANDARD nut. I linked a thread where was also a problem. No solution was found there either to my knowledge. It may be keyed or have some type of lock on the nut. It will move about 1/8th inch clockwise and counter clockwise but that is it. That is after being careful with a nice size drift.
This guy had the same problem http://coloradok5.com/forums/showthread.php?t=280708&highlight=spindle+nut
as did this guy http://www.steelsoldiers.com/cucv/47188-m1009-front-spindle-bearing-nuts.html
OK I DID remove the snap ring it is gone. Now the steel soliders link ^^ might be on to something. You cant loosen it if it has like a driftwood key in there.
