Melbatoast
Registered Member
I'm looking for some advice. I have a mostly stock M1008 CUCV with the typical 60/14bolt, 6.2L diesel (still naturally aspirated), TH400, NP208. This elk season my xcase took a dump... it keeps popping out of 2hi and 4hi, making a grinding noise. Only once I come to a complete stop, put it in 4low, move a bit, and put it back into 2hi will it stay engaged for a bit before randomly disengaging within a 1/4 mile. So I had to leave it at an Renegade Offroad in Kremmling, CO again (last elk season I broke my tranny), til I can come up with some dough to fix it. So here is my dilemma, do I take the easy route and get another NP208 from Boyce Equipment for $495 (had to do this in 2008), slap it in there and be done.. or spend roughly $1000 finding, rebuilding and going through the trouble of putting an NP205 in there? I'm currently running 35x12.5's with the detroit locker in the rear, but will be running 37x12.5's locked front and rear within the next month. I wheel quite a bit on local trails but from what I've read most people with NP208's have no problem with similar setups. I don't plan on running a more powerful engine than the 6.2L diesel, and I like the lower gear ratio the NP208 provides (especially with the 37's I'll be running soon). But if I have to replace my NP208 again in 4 years I might as well just upgrade to the NP205 now. So did I just get a faulty NP208 from Boyce in '08? What would you do... replace the NP208 with another, or go through the trouble of putting an NP205 in there, sacrificing the lower gear ratio?
Also, anyone ever mess around with the rear M1008 spring packs in order to get better flex without losing ride height?
Thanks Fellas, I look forward to your opinions.
. I found a few options, quick question... does the NP241 use the same adaptor as the NP208 to hook up to the TH400?
