bot0611
Im doing some thinking in getting me a air compressor system maybe Warns.
But there are electric compressors as well, wich is better mechanically driven or electrica.
scratch the tank if you go empty your done id preffer the compressor.
I love my york compressor and it can be done fairly cheap if you can turn a wrench and have access to a junkyard. I pulled the york, a couple mounting brackets and some relays from a junkyard for about $50. Cut and tacked the brackets together to make something that would fit. Then I got a 10 gallon tank, some air hose and fittings from tsc for another $50 or so and wired and plumbed it up. Definitely on of my favorite mods so farThe electric ones do not put out anywhere near what the York compressor does. So to each his/her own.
For an engine driven compressor? a york ac compressor is about the easiest way to go, although there are a few others that people have made work. Do a quick search for "york compressor" or "oba" there are lots of threads and pictures on this site.ok so whats a good brand and can i see some pics
