I ran in to a guy that had built this home made shackle flip. All he did was grind away the factory hanger a bit for clearance. Then, build a heafty shackle that fit on the outside. Seams like a cheap and easy way to do a flip. But, whats the downside?
I don't really understand shackle angle I guess . I always liked it in the middle so the shackle can swing forward AND backward equal amounts .
I guess mine is a little rearward to begin with , and it works well :
Thanks Chris , I don't think I was paying attention before , that helps![]()
So Pauly if Im seeing what I think im seeing, you are basically running the same thing I have pictured. You just made a bracket to use your factory shackle instead of a new shackle like in my pic. Is that correct? Also, how thick is the metal you used, and does the bracket swivel on the top and bottom?
Yeah, the shackle angle is much more complex than any of us give it credit.
