And for those running stock 10 bolt/Dana 44 shafts that want more from their front shafts but dont want to drop coin on chromo stuff
Grind or machine your stock shafts for full circle snap rings and run Spicer 5-760x joints.Most stock shaft failures I have seen in the joint area are due to the half clips comming out,the cap falling out,and in turn pulling the ears outa the shaft.
With the full circle snap rings the cap cant fall out.I have run stock Dana 44 shafts with the ears stretched .030+ for longer than I thought possible before failure.
And the Spicer 760s tore the ears out of both of my Warn chromo shaft failures.For an off the shelf stock type joint these are as good as you can git
And just for refrence value
On my one 60 shaft failure,my Spicer 35 spline outer and 5-806 joint was stronger that a stock non neck down outer.Had I been able to find the caps with all the needle bearings intact,I could have just replaced the inner and been good to go
Ok Im done spewing useless info
