HarrisonTX
I see alot of k5s on here with the front fenders, behind the tires trimmed for tire clearence. Right now im rockin the stock 31's with no lift on my '86. I see lots of 4'' kits for around $500, and i could get some 33'' tires for around $800, I spend alot of time studying the "xx lift with xx tires" thread, trying to learn what looks best for me. Some of the guys with 33's and 4'' of lift look like the are really close to that fender, and with any kind of flex would be alllll up in the fender area, some guys look just fine.
I guess if you never take your truck off road, you would be fine. I will bring to truck to Colorado with me, when i get home, and plan to just do some trail riding with it, nothing major, but it WILL see off-road use
Does anyone have something close to 4'' with 33''s?
Also, im new to 4x4s, spent most of my time on the hot rod scene.
Where can i learn the difference in lift kits, IE:
shackle flip, blocks, springs, zero rate, longer shackles
The kits im seeing on 4wheelparts.com for 4'' is simply new springs, and longer u bolts. Im assuming i would need shocks too?
btw, im trying to avoiding trimming the fenders.
Thanks guys
Thanks guys
) but if you keep your sway bar intact you should not have a problem at all. i can show you pics of it flexed with my sway bar still on and you can see for yourself if you want.
And yes, you'll need new shocks too.
