Where does the Oil Pressure sending unit go?
trevmountain
Jackson, WY
Oil pressure sending unit? I guess that's what it's called. The little bulb looking thing that screws into the block (454) and has a little connector on the end for a wire. Any way where the heck does this thing go? I can't remember where it was when I pulled my motor out and it got taken off by the machine shop.
Just trying to put my motor back together and the chilton manual is completely worthless.
On my 468 I used the oil port right above the oil filter. I used an aftermarket gauge though and there might be clearance issue's for a long sender with exh manifolds.
