dstrbdxp-AK
Registered Member
So Napa and Schucks have no listing for a wiper/washer switch.
Basicly the 2-wire washer connector corroded off the pump, so I went to the 11515 Trico pump which cancels out the cam style pump and uses a regular electric pump in the original housing. So I push the button once to activate it and check the spray, and the pump runs for a solid 10 seconds, stops, then the wipers come on.
Sounds to me like a short in the switch, no biggie it's probably original.
But where can I find one? Short of spending $70 at LMC?
Is that an intermittent switch? It's obviously a variable speed motor, but the rotary knob make the think it's intermittent.
