Which tire is close to a 35?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by AntAZBlaz, Apr 2, 2002.
  1. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    I was wondering which tire is close to a 35 when they use 285/75r16 type of codes? I would like to pick out a 35/12.5/17 or 16. but they are all measured with the other sysem.
  2. chaka454
    chaka454 1/2 ton status
    Nov 13, 2001
    199
    California
    I believe it's the 315/85/16 the ones I got are 35s and they are 315s but if I'm wrong somebody please feel free to step in.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  4. AntAZBlaz
    273
    Mesa AZ
    I was looking to buy some MTR's some day and the larger rims are all measured in the other system.
  5. jeffer
    jeffer 1/2 ton status
    Nov 6, 2000
    113
    Loveland, Colorado
    Here's how to figure that. With the 285/75r16 system.
    285=Section Width (mm),
    75 = Aspect Ratio (%),
    16 = Rim Diameter (inch).
    How to figure real tire height: H=2*(Section Width)*(Aspect Ratio)/100/25.4(mm/inch) + Rim Diameter
    So, if you want 12.5 inch wide = 12.5inch*25.4mm/inch = 317.5mm --> go with a 315 tire.
    For 17inch rims, a 315/75R17 tire will be 35.6/12.4/17 or a 315/70R17 tire will be 34.4/12.4/17
    For 16inch rims, a 315/75R16 tire will be 34.6/12.4/16 or a 315/80R16 tire will be 35.8/12.4/16
    The 315/85R16's would actually be 37.1/12.4/16. But, there are only so many combos available so take what you can get.
    I've seen websites before with all possible combinations and their 'real' dimensions, just can't remember where. Hope that helps.
    Jeff.
