I've been exploring dropping a 6.0 in my truck for quite awhile because I'm unhappy with my current engine. plus I want EFI pretty badly.
However, every time I mention that I have a 383 people react like it should be a sweet motor, but it's not. This has always puzzled me because I just haven't been impressed with it. Then, this past weekend while camping one of the guys up there mentioned that he thought my truck sounded like it needed bigger exhaust and it got me thinking... maybe I've just set this thing up all wrong. If I set it up correctly maybe I will like it after all.
I've decided to give it a shot before I proceed with a swap, so hopefully you all can help me figure out what I'm doing wrong.
current setup:
stock exhaust manifolds, dual 2" all the way out the back.
edelbrock carb 600 I think.
HEI ignition all stock GM stuff.
I'll have to check on the heads, but I'll assume nothing fancy there.
The biggest issue I have at the moment is pinging. I've adjusted the timing all over the place and even using 91 octane gas I get pinging. I can't really put my foot in it at all because if it. Solving that issue would be first priority. Hard to get any low end torque if you can't give it any gas for fear of pinging.
current setup:
. I did have some carb problems, but it still made good power on the bottom end.
) for a daily driver you might be disappointed in your 383
