dave w
I'm putting together a budget SBC 350. The crank has been turned 10 / 10. I was wondering if the plastigage will show if one of the mains is misaligned? I was thinking if I put a piece of plastigage on both the bottom and top main bearings, I might be able to see a misalignment? My thinking is; if all the mains were straight, then it really would not matter if the plastigage was on the top or bottom of the main bearing. My thinking is; if plastigage is on the top and bottom of the main bearing and there is a misalignment, I would see noticeable difference in the plastigage measurement bottom / top?
Any advice is appreciated!
dave w
dave w
All the freeze plugs were in, and a slight amount of antifreeze drained from the block when I turned the block upside down.
