Cornfield creations
I have installed the 95 windstar fans on my 79 k-5. I am trying to keep the temp up a little on my new 350 HO engine to keep it from building up carbon in the cylinders and to run cleaner all around. My temp switch is one from an 87 camaro, and is set at 210 I believe and a 180 thermostat. I was wanting to wire up one of the fans to turn on automatically to pull air through to cool off my A/c.
My question is which fan of the two would be the best to wire up? When I turn on the driver side fan it seems to cool off the radiator real quick and drop the engine temp. When I turn on the pass. side it seems to not cool off the a/c enough. It doesn't blow cold in town, but it does on the highway. I had a problem after I installed the fans that the temp built up and blew off the PRL on the back of the compressor and smoked my compressor belt.
I was thinking to wire up the driver side, and maybe put in a 195 thermostat in the engine to keep the temp up. I think thats what a GM tech told me should be in it.
Any suggestions to keep the a/c cool while keeping engine temp up?
