I've got some under-dash electrical gremlins I'm dealing with, and I need some reference material.
My diesel Suburban ('94 C2500 Silverado) will randomly stall or not start, and the guages go blank when this happens. It usually happens when theres a shock (like a road bump) or I move the column/shifter/turn signal lever. I replaced the ignition switch (common known failure item) and the problem was not solved. If I reach under the dash and wiggle wiring bundles it will temporarily fix the problem. There are Scotchlok connectors and butt splices under there from the previous owner
At any rate, I need to know which wires do what so that I can properly address the issue. Anybody have a suitable wiring diagram that they could share?
