Wtb Cummins Inline P7100 Injection Pump for 4BT
bhays
Ridgecrest, CA
Looking for all the lines, pump, and etc.
Thanks,
Have all the stuff for a 6bt but it's probably different.
On another topic I'd like to see your D-Max. I'm getting closering to doing one,not sure if one I have or if I'll pick up a 4door.
What size tires do you what to run? I have the Pure Performance Prerunner system. I like it alot. I uses the AAM out of the late model dodges, so you do not have to worry about ABS sensors and etc. If I was to do it again, I would design the kit mayself to save money and change some of the things about the kit I do not like. I plan on starting a biuld thread... What are you using the truck for?
Thanks,
Going to be very hard to find, not many were used. Make sure you know there is a P3000 which looks very close the P7100 but they are different.
The fuel lines can be used from a 6bt ,the I/P gear can also be used.You'll also need the timing housing,lift pump .
Buddy of mine is looking for you. PM me your number and I'll pass it along.
Do you still have the stuff for a 6BT? I know someone that maybe interested.
Zach Hamiliton of Hamiliton Diesel in Texas (maker of aftermarket Diesel camshafts & a custom 12V cylinder head) bought a pallet full of 4BT Ppumps last year not sure if he ever sold them all but would be worth a phone call as the inline pumps for the 4BT are hard to find.
Appreciate it!
