wtb manual column for 89 suburban
jovibuilt
Registered Member
spruce pine nc 28777
I have a 89 burb that I am coverting to a manual.I have everything but the steering column.I need a tilt column with delay wipers.I dont have cruise control.Looking for a good one.Let me know what you got I need it shipped to 28777.Thanks
good luck those are rare.
all i did was pop the pin pull the shifter handle.
also make a small bracket to hole the linkage un in park on the engine side of the firewall and bolt to a body bolt that holds the speedo cable. this will let you lock the wheel and pull the key.
otherwise you might be waiting for a bit to find a tilt manual setup for 85-91
yeah good luck those columns are uber-rare. your best bet is do to like Sweetk30 said or do with out tilt
