Just got the engine all finished up, replaced that cracked supply line with the one that Brian (Wrench) was kind enough to offer me.
Bled it all out, filled it with coolant, started right up. Drove it up to the front of the house to top the rad off with a gallon or so of water, and noticed a major fuel leak off the side of the injection pump where the throttle shaft runs through the IP. Also spot two coolant leaks, one off one of the rear crossover plates, and one off the upper rad hose thermostat side.
Figure I'll park the truck inside now that the engine is in and running, so I can fix up those leaks and replace the front differential. Leave it idling just outside the shop while I run inside to move the other truck out of the shop so I can put the 86 in. During the time that it took me to start the other truck and pull it out of the shop the 86 had stopped running. Figured that was weird, cause it was high idling smoothly with a very healthy rattle, but thought it might have come off high idle and stalled out due to the screw being set too low or something.
Hop in to start it up, and the truck cranks very slowly while making a squeaking sound
Starts back up, but immediately dies. Try again, and the engine won't even turn over. I tried turning it over by hand, and I can't move the crank
Seized solid.
So, the $1000 bucks I just dropped on buying the engine and replacing the timing chain, putting a main girdle in, new glow plugs, injectors and other crap for the thing was totally thrown down the toilet. Not to mention 3 weeks of labour outside in - friggin' 40 weather for absolutely nothing.
I am NOT happy.
Seized solid.So, the $1000 bucks I just dropped on buying the engine and replacing the timing chain, putting a main girdle in, new glow plugs, injectors and other crap for the thing was totally thrown down the toilet. Not to mention 3 weeks of labour outside in - friggin' 40 weather for absolutely nothing.
I am NOT happy.
