This is the general idea of what I'm doing. As you can see in my pictures, the whole rocker area is trashed. The floorboards are also gone. What I'm looking for is pictures of how you guys re-built where the cab mount is. I'm thinking about getting some material about the same size as the factory cab mount but thicker, and then tieing it into the tube in the rocker to make everything a little stronger. Doing something similar on the back (even thought the mounts are inboard of the frame). I know I'll have something below the floorboards (which I'll be replacing with a heavier materail of some kind) but I don't see any problems as alot of the pictures/threads you linked had just tubes down below. Thanks for the good picture threads man!
