Daily Driver 82 K5
The pit.
I had grown up with Mustangs old Fords and a 68 Nova which was my daily driver for 12 years. I eventually found myself with new cars, what I call throwaway cars. Now I’m 50 and back into the old V8’s. It’s been about 20 years and I’m realizing that I don’t have the skills or ambition that
A - Youth brought
B - Being mostly broke brought.
During the pandemic, I sold my beloved 4Runner and bought an over priced 82 Blazer. It did have a rebuilt motor and rebuilt transmission, but it had been sitting for years. Aside from that, it was missing a lot. A lot of which I didn’t even realize at the time. Additionally, somebody had cut a sunroof into the top. All I’ll say is measure twice, cut once! I was looking for a challenge and I got one. Within the first 10 months, I put about $13,000 into it. Some cosmetics and mechanical. A comprehensive list is noted below. I’m Including this just because I find it interesting. Unless you are a real do it yourself-er, a shop may be part of your story too. This is now my daily driver and at 9 miles a gallon I love it. I drive all over the place at six bucks a gallon!
Even passes California smog.
-Blazer initial cost $8000
-Merrick’s rear seat brackets $600
-Used rear seats $150
-Tires $950 33/12.5/16
-3Pt seatbelts x2 $205
-Dome light and lens $25
-Glove box $30
-Door sill plates $30
-Sound deadener $175
-Molded carpet set $340
-Dash bezel $150
-Printed gauge circuit board $65
-Armrest set $60
-Steering wheel $120
-Steering wheel install kit $27
-Steering Stabilizer $100
-Billet horn button $40
-Temp control assembly w/AC $85
-Coverlay dash cover $180
-Lower door panel’s $80
-Door seals - body - $45
-Front bumper brackets $108
-Upper grill trim $30
-Soft top $1200
-New driver seat $200
-Driver seat upholstery $250
-Roll bar $750
-Driver wing window rubber install $75
-New passenger wing window (broke it) and new rubber install -$175
-New driveline, shaft seal, transfer case fluid and transmission mounts $400
-Shop - Complete stereo installed with Retrosound head unit, Retrosound center dash speaker, Hertz side dash speakers $660
-Shop - Complete exhaust $550
-Shop - Complete rear axle/differential rebuild $1500
-Shop - Complete front end; upper/lower ball joints, new tie rod ends, rotors, pads, install stainless brake lines parts/labor $1690
-Shop - Resealed intake manifold, new water neck/thermostat, water pump plugs, wires, exhaust manifolds, valve covers/bolts/spreaders, vacuum lines parts/labor $1725
-Shop - Carb adjust and lights repair. Installed new dash circuit board. All dash lights, blinkers, flashers, tail, brake, marker and headlights are now fully functional Labor $400
-Shop - Mini starter, triple gauge install, pinion leak $600
Donor roof $400
Labor on Sunroof $600
Initial pic, when picked up. 32” tires.
1982
Blazer
Merrick’s rear seat brackets, 99 Blazer front seats, 05 3rd row rear seats.
4WD, AC, PS, PB, PW,Power door locks
350
700R4
6”
Dana 44 up front, 4:56 gears.
15”
35” Cooper Mud
N/a
Chris Ziemer
753
