KS ‘74 K5 chassis
thatK30guy
1 ton status
‘74 K5 frame, 4.10 DRW 60 and 70, DIY4X parts, brand new 52’s and used 64’s, old pic lockouts are gone. Located in central Kansas asking $2000.
Willing to part out if anyone is interested but would rather sell springs with their hangers and hardware and axles as a set since I don't want to be stuck with a rear if the front sells.
If only you were closer. Awesome starting point for ground up build.
I should have towed that back to Houston with me when I picked up the big block..:waytogo:
I don't think it was assembled back then like what you see in the pics. I did have the frame for sure but nothing else at that time.
thought you had those axles in the back driveway...just not under the frame...
still have the furd highboy?
I remember I had another set of axles under this frame but different springs, too. The Highboy is long gone. Parted all that out and delivered the frame to a guy in Dallas on my way down to Fort Polk to pick up an M1008 a couple years ago.
Parting out. Keeping the D60, u-bolts and plates. Everything else is up for grabs.
