Banjer Picker
Registered Member
- Joined
- Sep 4, 2016
- Posts
- 15
- Reaction score
- 1
Greetings cK5-ers.
Picked up a ‘74 K5 a couple years back. Has 350 motor and 350 trans. Has never been started since I bought it. PO didn’t know much about the history of the vehicle either.
Finally getting around to to digging in to it. First step is to see if the motor will crank. (Was able to turn crank so it’s not seized)
Most of the vacuum and fuel lines lines to and from the carb ar missing. Can you guys recommend a good link or good pictures to a “dumbed down version” of how the hoses and lines are routed (assume stock set up).
I haven’t picked up a chitons manual yet and all the diagrams that I found on the web were tough to follow.
Appreciate any and and all help!!!
Brandon
Brandon
