‘75 Fullvert Blazer- K5 Cody’s build- 8.1 swap***48 days to C10’s in the Park***
Restomod build for a late friend
Wish mine didn't. 150k on it now uses @1 quart every 6 tanks. I should have done it when I did the intake gaskets
I probably should on this one. It’s clean inside, but not as clean as my first one. So, maybe I should look into that to be safe.
Ok I’m in love with this super satin black by Columbia coatings paired with duplicolor Chevy red-orange. The welding teacher showed me how to set everything up so I can powder coat during the summer while school is out. Plan is to get some white for the wheels and who knows what else.
Also spent some time tonight on the tedious stuff. Wire wheeled the valve cover bolts. Now waiting for the new grommets and gasket kit.
It's turning out great!
You'll get better mileage, that big ass 496 won't have to work at all. Not like a treefiddy will anyway.
What trans you got behind the 8.1?
I’d say in the world of 8.1 swaps this might be the only one strapped to a TH350. And since I’ve killed a couple of those with a mild 350 small block I can say that poor TH350 may not have a long future coming up.
Anybody want to start the over/under on its demise? :whistle:
Just though this but what flexplate are you using to mate up the 350 torque converter?
So funny you say that. My crawler has been paired with a 700r4 for over a year, and so far I’ve killed 2 driveshafts and zero transmissions lol.
Factory small block flywheel matches up to both. So I just reused the flywheel from the original engine. Same thing I did with the crawler.
Are they not externally balanced on a BB?
