‘88 K5 axle seal replacement
For the inner seal on a front axle you'll need to pull both axles and remove the differential, the seal installs from the inside of the housing. There's no need to remove the pinion, just the diff. If the diff carrier bearing caps are not already marked, take time to do so to ensure you reinstall each cap on it's original side and in it's correct orientation.
