‘99 c3500 master cylinder part #?
shock88
Electric Pole Dancer
CT
hey guys sorry for most likely a repeat post, but i’m installing my rear disc on my new build and i can’t find the correct part number for the master cylinder off a ‘99 c3500 **with rear disc** advanced and auto zones sites do not state w/ rear disc or not. i just want to grab the correct one the first time. i’ll continue to search in the mean time!
i’m keeping my factory vacuum booster also
i found a part number....cardone #102754...sound about right?
That's it. That's the part number listed in the part number thread and the same one I used, works great!
try c3500 HD truck with the 5lug front and 10 lug rear . there factory disc on both ends .
i am using just a k30 master /hydroboost and 1/2 ton rear calipers and no problems stopping and firm pedal up near the top like stock .
hydroboost and vac also have different size bore specs were it fits in the vac or hydroboost body and the 2 studs hold it in place . so look in to this also or you could have a fitment or vac leak problem .
I have a C3500 (disc-disc)Hydro master bolted to a vacuum booster.
