So I have this gauge cluster I built from various pieces:
I used a 0-100psi electric oil pressure gauge. Apparently, that is very not normal. Since I used a standard sending unit from mid 80's truck, that sending unit is probably for a 0-60psi gauge, which seems to be far more common.
Trouble is, I can't find a sending unit for a 100psi gauge. Med. duty parts seem to be alot harder to find, tech's at dealers don't want to waste their time on an oddball lookup.
The way it's installed I have anywhere from 50-100psi pressure showing while the engine is running. I don't believe that's right. I supposed I could swap the gauge itself for a 0-60psi one. But I'd rather find the right sending unit if I could.
I don't remember exactly where I got the gauge. I believe it was the same leftover cab from some med. duty truck I pulled the Tach/Fuel gauge and the air gauge from (btw, that air gauge is nice, stock GM, and it has dual different colored needles with dual air inputs so you can monitor regulated and unregulated OBA). It was late in the yard one day,getting dark, as I was walking back with another part in my hand, I notice this med. duty cab laying on it's side, not on a frame or anything and I happen to notice the cluster, saw it had a tach/fuel I was looking for and pulled it. Best part was he sold it to me for $30. Those tach/fuel gauges with a working printed circuit on the back of the cluster go for $200-300.
Anyway, does anyone know a year and model of vehicle that this 0-100psi electric oil pressure gauge would have come from?
