Truck:
01 2500HD CCSB 4X4
LB7 Duramax
Allison automatic transmission
416k miles
Started the truck yesterday. Didn't let it warm up long. Backed out the drive. Goose the throttle to see how the roads were. (We've had rain, sleet, etc lately and I wasn't sure if it would be slick. It wasn't.)
Truck starts forward, then is in neutral. Shows in drive still, but acts like neutral. Put it in neutral, then back in drive. Same thing, no go. Tried reverse, same thing.
Shut the truck off. Sit there in the middle of the road contemplating my options. Start the truck up, try shifting the transfer case to 4 HI. Put it in gear and forward works. Ok, maybe the transfer case had went into neutral for some reason. Shift back to 2 HI. Drive 15 miles to work. Had a service engine soon light for a bit, but went away. Checked transmission fluid and found it low. Added a quart. Seemed to be fine. Drove home that night. No problems. Drove to work this morning. No problems.
Left work tonight, made it a quarter mile and we're in neutral again despite being in gear. Same story. No forward, no reverse, light came on. Fluid level is fine. Shut it off, restarted, tried shifting transfer case again, away we go.
Stopped at the Oriellys, pulled the codes.
P1713
P0700
Anybody seen this before? Or have suggestions on how to diagnose it, short of taking it to someone? I can fix about anything, but automatic transmissions are not my strong suit.
01 2500HD CCSB 4X4
LB7 Duramax
416k miles
P1713
P0700
