01maroonz71 here are the rim pics
73K5Kid
chandler az
Sorry I took so long. Grinding is not that bad on the front calipers with 4 1/8 backspacing. I think the 15x10 look good you could get away with 15x8 its just whatever flavor you prefer. If you have any questions let me know.
awesome man...thanks alot!!!!! maybe the skinnier wheelbase will make it more "road friendly" you know.
how hard are those wheels to keep clean???
No problem so are you going to go with the 15x10 or the 15x8? They are not bad to keep clean. I use it as a daily driver once or twice a week. Now if you are offroading I have no idea. :woot:
Where did you get the wheels from. I like the look of those, although I would prefer white, but an 8 lug 15 like that would be ideal for the 33X12.50 that I plan on running after the lift and new axles.
i just ordered the exact wheels you have...15x10 4.25BS in chrome....it was 285.00shipped from summit. can't go wrong for that price.
i didn't order centercaps b/c of my manual hubs in the front and the FF hub design of my 14bolt. im gonna see how that looks in the rear, if it looks no good...then she said centercaps were 20bucks each.
im gonna mount my 38x15.50mud grapplers on them and install the 8in BDS and my high steer setup that i am accumulating right now. from there, once i reach the limits of my 10bolt, i will go D60. :) thanks alot man, you've been a big help.
I may do the center caps on the rear as I have a line on a 14sf for my rear end, but who knows, by the time I get the cash I may find a full float for the rear. Those look sweet with that backspacing, mine is a little less so they are tucked a little further, but I like that look.
01maroonz71 said:
i didn't order center caps b/c of my manual hubs in the front and the FF hub design of my 14bolt.
make sure you paint your rear hubs and axle shafts black along with the front hubs. or get the open center caps for all 4 wheels.
with a 14 bolt you will probably never need to pull the axle shaft without the wheel. because you will not break it. so closed caps would be fine. I personally like to see the axle ends sticking through the wheel, you may not.
Those look like Mickey Thompson ATZs...
How are they on the street? How do they ride? How do they wear?
The ride is quite nice considering its a 4x4. They are quiet on the highway with a nice hum. I can still hear my stereo.
But much quieter than a mud tire?
How do they compare to the BFG All Terrain?
